splines help. instant off track
Started by gokitty199 (A), September 04, 2014, 12:05:15 AM
it looks all ok???, the only thing maybe is all the nodes on the start line aren't in a straight line, try tidying those up and give it another go!
gokitty199 (A)
Quote from: al167 on September 07, 2014, 08:50:51 AM
i have done that multiple times and redone it. they were straight before i took the pic but im still having that same issue for some reason, its weird.
Here's a couple of ideas, 1) try moving the start line back behind the startgate, 2) move the center green square on the first node of the funnel back so that it sits behind an imaginery line that joins the other 4 points in th 1st node.
There is also one of the Zone file areas (zone1 i think) that affects the bike but i think thats more the reset than off track message but might be worth checking..
gokitty199 (A)
Quote from: mcm2boys on September 08, 2014, 09:09:02 AM
its not the zone files and i tried both of those and nothing has worked so far i still reset at the exact same point. its acting like its not starting in the splines, i made sure and resized my terrain file to 1024x1024(it was at 1025) and that didnt change anything. no matter what i move its always in the same spot that resets me
if you don't mind exporting and sending me just the spline and i will take a look and see if i can work out what's going on..
