Questions, Suggestions, AND Thanks To TD...
Started by v_hoOk~ (A), January 24, 2005, 09:03:46 PM
v_hoOk~ (A)
aaron.270 (A)
Quote from: cR on January 25, 2005, 03:51:59 AM
They are stored in .DAT files wich are located in the UI dir,
LOADBAJA.DAT
LOADNAT.DAT
LOADQUAR.DAT
LOADSX.DAT
LOADTAG.DAT
LOADEND.DAT
The file structure inside is like this,
Root
+ Loading this is a folder containing the .tga files
| |- BlueBar.tga the loading bar, 251x11 at 16 bit
| |- type.tga the fullscreen image, 640x480 at 16bit, pixels, type can be baja, national, quarry, supercross, tag or end
|- loadTYPE.dtm contains data on size, position etc., type can be BAJA, NATIONAL, QUARRY, SUPERCROSS, TAG or END
Example:
How do you open and change the files contained within the dat files because I might like to try and make some load screens myself.
v_hoOk~ (A)
v_hoOk~ (A)
its slang use in the mcm community meaning you dont have  privilege to view something or your not smart enough or its in the works, or slang to say im way better and smarter than you so just hold up while i finish it and i may just share my knowledge and make you wait... either or
