MX Reflex Skin DLC Packager v0.9.5.3
Started by mcm2boys, July 18, 2014, 12:54:26 PM
BigFluffyChiken (A)
Right, but when the window opens, it only lets me select folders in the program folders files of the C drive. There's no way for me to go backwards and select the different drive where it's actually installed.
MxRyan195 (A)
Is it possible to get the bmp file for the alpinestar tech 10s? I want to try to make 2013 ones.
Akoub816 (A)
Could somebody explain the name/number tab on the dlc compiler? How does that work?
Quote from: Akoub816 on December 18, 2014, 01:52:17 PM
Put an image with a black alpha channel here to remove the name and number.  That way you can have your own permanent design on the bike or jersey instead.
BertV (A)
#124
Quote from: JamieT on December 18, 2014, 06:33:34 PM
Can you give an example how to do, or send the file the we must paste in? i didn't understand
ayastuy4 (A)
such as database open and package?
for editing in (MX SLR Skin packager)?
Quote from: ayastuy4 on January 01, 2015, 11:01:08 AM
What's this? "SLR Skin packager" ???
You can't open the database or package files for skins, you use this tool.
ayastuy4 (A)
ayastuy4 (A)
#130
No, you don't "edit" any skins.  You only make new skins.
Install the tool >> http://bruceatkinson.com/dirttwister/smf/index.php/topic,4590.msg26886.html#msg26886
Then look in the install directory for "Wireframes" folder.  That will give you a guidline to start making new skins.
szalonym1 (A)
Hi guys ;D It is possible add new color wheels or exhaust?
Not right now, the packager doesn't support it yet..
szalonym1 (A)
Thanks mcm2boys. I hope will be possible soon. ;D
Stevo (A)
I'm not sure if this has been patched yet but I am unable to locate my steam folder because I put steam on a second partition and the software only allows me to select steam from within the Programs files. Steam is in my second partition aka "Local Disk (D:)" as apposed to the standard "Local Disk (C:). So I cannot open the software, is there a way around this?
from memory,
make dummy folders in the c location copying all game data over aswell:
C:\Program Files (x86)\Steam\SteamApps\common\MX vs ATV Reflex
then after you compile a track, copy the track files to the other d directory version.
probably would be easier to just reinstall in that location.
The packager should be able to find Reflex on your D: drive now, though Steam swaps things around from time to time so it may stop working again at some point. So there is also a last resort that if it can't find it it will ask you to select the games root folder and store that for future use.
Did you try it and it didn't work?
JamieT found a small bug in the packager, so an update is available in the first post.
SUMMUS (A)
Hi guys, can anyone tell me how to make a new brand?
I want to do one industries gear and  DLC Packager has an option to do new brand but i dont know how to do it
Thanks.. Cumps
Quote from: SUMMUS on March 01, 2015, 09:56:21 AM
I think brands are only possible for bikes at the moment.
